Coolant Nipple for Audi I5 Block ?
  • sailaz
    • Oct 2009
    • 647
    • Country: United Nations
    https://store.034motorsport.com/cool...-i5-block.html
    Could somebody point me please where this one is located ?
    Accidentally came across this nipple on 034 webpage, started thinking where it is located on the block and now got pi***d of just because can't figure out ..
  • A1QSHIP
    • Aug 2004
    • 975
    Back of engine block just below cylinder head. There will be a heater hose attached to it.
    "Nulla tenaci invia est via"
    • SteveH
      • 4460
      Looks like the pipe which is fitted to the side of the thermostat housing.
      91 Modded 3B
      14 A6 Avant Black Edition
        • sailaz
          • Oct 2009
          • 647
          Could you please point where, please ?
          Where I pointed red arrow goes this one:
          • sailaz
            • Oct 2009
            • 647
            Here ?
            • LHD_Kid
              • May 2006
              • 3696
              https://store.034motorsport.com/bloc...arly-22mm.html
              Yeah, but the 034 one has no corrosion resistive coating. Bare alloy...
              • sailaz
                • Oct 2009
                • 647
                better that alloy then plastic ----- pain in the *** unreal
                P.S. but still...... where goes this one , question stays open
                • SteveH
                  • 4460
                  Here ?
                  Under the 90 degree pipe with a bolt in the end if it.
                  91 Modded 3B
                  • sailaz
                    • Oct 2009
                    • 647
                    Looks like this one ?
                    • SteveH
                      • 4460
                      You got it!
                      91 Modded 3B
                      • sailaz
                        • Oct 2009
                        • 647
                        You got it!
                        probably (and most likely) I will go to celebrate that or I just need an excuse
