I'm just wondering if anyone who already upgraded
the con rods on I5,have you balanced the engine?
Is it necessary to drill out the counterweight to compensate
the weight loss from the lighter con rods?
For example when rebuilding the AAN,we
Upgraded from stock rods (weight = x grams),
The I beams conrods ( weight = x - 0.5 grams)
Let's say we're using the stock wrist pins,
Stock pistons,rings.On bob weight calculation,
We're using the weight of the small end,big ends
100% of rotating mass + 50% reciprocating mass(
stock piston,rings,wrist pins) and drill out the counter
weight? Is this balancing necessary on 5 cylinder engine?
