Dump valve-where to install?
  • dkw_dude
    • 555
    • Country: Norway
    Good evening!
    I'm considering installing a 50 mm dump valve, recommended placement is as close as possible to the TB. On my setup I would like to install it between turbo and IC (more space and I already have stainless tubing there to weld the DV flange to).
    Will this placement give notably less good spool?? (I heard a theory that close to TB is best because then the air don't have to suddenly change direction).
    Leif-Helge
    -91 S2 VEMS and Comp Turbo
    -12 B** 530XD Touring "S2 parts transporter, and daily driver"
