Good evening!
I'm considering installing a 50 mm dump valve, recommended placement is as close as possible to the TB. On my setup I would like to install it between turbo and IC (more space and I already have stainless tubing there to weld the DV flange to).
Will this placement give notably less good spool?? (I heard a theory that close to TB is best because then the air don't have to suddenly change direction).
