What is the correct running temp?
  • martin richards
    • Dec 2004
    • 76
    I've just seen the pictures of WBRV mines not plumbed in like that. The pipe of the T-piece goes to the inlet(air box -turbo) the other two pipes are connect together with a short piece of pipe, i know all this as i have just replace all small pipe work down there for silicon piping? Is this wrong?
    • Patrick
      • Nov 2003
      • 18
      Faulty lambda probe? I had this problem and fuel economy improved 25%.
      Just my 2 cents; hopefully you get the problem solved!!!
      completely stock S2 except for the brakes and airfilter
      • martin richards
        • Dec 2004
        • 76
        lambda probe changed, the more money i put into it the worst the car gets!! reminds me of my old cosworth
        • Patrick
          • Nov 2003
          • 18
          sensor air / fuel ratio in the inletmanifold maybe??
          I had this one changed together with the lambda probe ; costed me aprox 300,- euro at the stealers..
          Good luck!
          • martin richards
            • Dec 2004
            • 76
            #20
            looking at the WBRV diagram, i don't get? What should the three pipes connect to? currently, Longone opposite the wiring plug connector goes into the inlet pipe. The other 2 are connected together.
            • Ski
              • 2591
              #21
              I used to get 22 mpg as when it was my daily driver. Now as my weekend fun car I get 18 ish.
              I guess im not the only one then
              ABY Coupe
              • alg
                • Apr 2004
                • 1160
                #22
                Originally posted by Ski
                my average is 17mpg, and my temp in traffic hits around 95, when driving can drop to 85.
                i think i have issues...
                can someone explain this to me please, ive asked before with no reply.
                My fan (3rd speed?) kicks in when the temp reaches around 95, but if I turn off my engine while the fan is on, the fan turns off too. I know others cars keep the fan running even if u stop engine and lock car. mine dosnt. any clues?
                All the same. The fan will come back on in circumstances when temperature rises again. Only noted on mine when unloading car after drive skiing at top of mountain.
                My SAAB used to run fan after switching ignition off but the S2 and now RS2 do not.
                Alastair
                RS2
                • Ski
                  • 2591
                  #23
                  ahh ok :/ thanx buddie
                  ABY Coupe
                  • alg
                    • Apr 2004
                    • 1160
                    #24
                    Originally posted by martin richards
                    15 miles on 1/4 of a tank. I don't believe this cars been chipped, have had a chipped S6(5 pot) and that was considerable quicker once moving.
                    Assuming you have used a boost gauge to get the reading you mention and the figure is not adjusted for atmos pressure I think it is chipped. Paul quotes 1.4 max boost for standard homefry
                    Check Paul's excellent reference http://www.s2central.net/main_frame.html
                    The other thought with that sort of fuel use is a boost leak
                    Have you checked for fault codes ?
                    Just noted you asked about this at the end of the year and had already done the obvious. Sorry if advice repeated
                    Alastair
                    RS2
                    • S2 Ant
                      • 3682
                      Originally posted by alg
                      Mine has risen since Mihnea custom re mapped the car. Well happy !
                      Mine also....... superb, more horses at WOT and more MPG at any other time.... superb!!
                      Ant
                      2011 Kawasaki Z1000
                      • The Spanish
                        • Nov 2003
                        • 719
                        #26
                        Originally posted by porkkis
                        Temp sensors can be affected by the wind.
                        Can you give me more info on this? because I always thought this. Is almost impossible those quick changes in temp when I am in the Motorway. 20 Degrees in <1min.
                        94' RS2 Coupe TT (Twin Torsen )
