Early AAN heads used a hall sensor in a distributor like the 3B's. Later AAN's were produced like the ABY's with the hall sensor being located under the cam sprocket.
Details of production dates in the link below. With the exception of the hall sensor location, the heads are interchangeable.
Early AAN heads used a hall sensor in a distributor like the 3B's. Later AAN's were produced like the ABY's with the hall sensor being located under the cam sprocket. Details of production dates in the link below. With the exception of the hall sensor location, the heads are interchangeable. http://forums.quattroworld.com/s4s6/msgs/121024.phtml
I see my work here is done.
