Can the maf be removed from motronic then? And can aftermarket rods be used with stock pistons?
Rs2 engine. Power potential on stock internals?
You need a speed-density tune and after it can throw MAF in the bin. Probably PRJ isn't the only one who can do it nowadays.
I have aftermarket rods on stock pistons. Engine is rock solid and runs like clockwork even though I have not re-balanced the bottom end after fitting them.Comment
I managed ~410hp and over 600nm with a .63 gt3071r (k24 flange) on stock ABY engine but with very very safe ignition map.
Even stock fuel pump maxed out. Was on its knees at that and starting to lean out to 12.0 afr however so not a good idea for long term but handy to know.Volcano ABY coupe
AntComment
