adjustable cam wheel with 7a cams
  • quattro-nick
    • Sep 2012
    • 1746
    • Country: Belgium
    hi guys
    i just wanted to know what is the best position for the 7a cams in our engines?
    if i use an adjustable cam wheel,shall i put the cams on factory marks or get i better results if you put the cams in an other position with a degree wheel on the crank?
    i'm not a specialist in cam timing but i want it to learn
    i can also use a adjustable cam wheel with adjustable chain wheels on the cams but maybe it's not worth the cost with what you gain?
    TWINCHARGED power,zero lag
    AEM W/M injection
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    if you only use one cam wheel then you are clocking both cams at the same time. think the best is to do them individualy? but im not expert
    • quattro-nick
      • Sep 2012
      • 1746
      • Country: Belgium
      i am aware of it if i dont use the adjustable chain wheels
      AEM W/M injection
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        I was searching the same topic But did not came Up with Any valid info about. Cam wheel cam chaim sprocket vs non adjust chain sprocket
        • quattro-nick
          • Sep 2012
          • 1746
          • Country: Belgium
          that's why i started this thread
          AEM W/M injection
          • V6quattro
            • Sep 2008
            • 949
            I use 7a cams and adjustable wheel. Gained lots of power adjusting it while tuning! But don't know at what timing I have them now sorry!
            1360kg/600Whp Avant 0-200km/h 9sec
            • V6quattro
              • Sep 2008
              • 949
              I also remember when I installed the adjustable wheel the timing was a half tooth out so that can also be the reason I gained about 100hp by adjusting the wheel as my timing wasn't right when I started.
              • quattro-nick
                • Sep 2012
                • 1746
                • Country: Belgium
                thanks roy
                AEM W/M injection
                • s2dk
                  • Jul 2016
                  • 507
                  • Country: Denmark
                  Was that the belt adjusteble wheel only or allspo one on the chain?
