ISV Test
  • Billman
    • 4129
    ISV Test
    Hi, people sorry for opening this thread but i cant find the infos on how t otest the ISV!
    Thanks a lot
    Go Holset or Go RS4
  • jameswkr
    • 538
    Resistance across pins appr 30 ohm. Disconnect and start her up/drive. Tickover will likely be faster and the car will be "jerky" to drive. Re connect and "discover" it is in fact working OK. Several on the forum including me suffer with a lazy ISV on first time idling - it seems to need to re learn each start up.
    • Fat Audi 80
      • 10547
      I think I get this occasionally. Most days the car starts and settles to a steady 750 - 800 rpm in a few seconds. But on other occasions, the car will "hunt" for a up to a minute or two before it settles down. I have no idea why but this sounds similar to the symptoms you are describing....
      Cheers,
      Steve
      The Perfectionist
      • Billman
        • 4129
        What happens if i connect 12 V to it?
        Go Holset or Go RS4
        • Nuvo
          • Nov 2003
          • 3825
          Without 12 volts it is always partially open, adding 12 volts will open the valve and reversing the polarity will close it IIRC.
          HTH Nuvo.
          • Mikes2
            • 1704
            You can use VAG Com to confirm it's operational by running the output tests.
            may help
            Mike
            http://www.s2-audi.co.uk
