Connecting rods question.
  • popdemonic
    • Dec 2007
    • 1304
    • Country: Thailand
    I just acquired the I Beams rods and noticed slightly scratch marks on the
    The axial face of the rods.would this be any problem when installed?
    h
    one of a few I5 from Asia.
  • SteveH
    • 4460
    Where are they from; who made them? The shot peeing looks very coarse and perhaps that's an indication of their quality. The marks look rather nasty, what's the rest of them like?
    91 Modded 3B
    14 A6 Avant Black Edition
    • popdemonic
      • Dec 2007
      • 1304
      • Country: Thailand
      I'm doubt the scratchs are from the shipment and poor packaging.
      n
      • SteveH
        • 4460
        They look like they've been rattled around against each other at some point. There is clearance on the axial side between the big end of the rod and the crank, so I can't see the marks affecting their use. I'd question how well they have been manufactured and handled before you received them.
        91 Modded 3B
        • piotr
          • Jul 2012
          • 1470
          Looks like transport damage,I think it's more cosmetic and should not cause any problems other than bad taste looking at it.Is there any numbers on the side of rods?
          • popdemonic
            • Dec 2007
            • 1304
            • Country: Thailand
            Unfortunately not.what's that important? Thanks!
            • popdemonic
              • Dec 2007
              • 1304
              • Country: Thailand
              Thanks Steve!
              • piotr
                • Jul 2012
                • 1470
                On my SCAT rods there was a numbers,and they match,so if you would mixed them up,then you might have a problem that rod will not fit perfectly if you know what I mean.
                • steve briance
                  • Aug 2014
                  • 1455
                  I would dress off any blurring where that mark is - its something that is so simple to do you might as well.
                  The other thing I'd be wanting to check is that there is no rifle drilling to supply oil to the gudgeon pin...
                  Ahhhh, just had a closer look at your pics and see there is a hole at the small end to let oil through, probably provide oil if splash lubrication is alright for you
                  • Thuppu
                    • 4115
                    Just torqe them down with plastigauge, check clearance, and if ok they will be ok.
                    • popdemonic
                      • Dec 2007
                      • 1304
                      • Country: Thailand
                      Thanks for all the replies guys.well it's all set and i'll be starting to rebuild the AAN soon.
