Wagner intercooler
  • piotr
    • Jul 2012
    • 1470
    Wagner intercooler
    Hi.im just about to fit Wagner intercooler to stock ABY crossmember and would be handy if someone could share the photo of that as I'm
    not 100% sure how to fit the bracket that comes with new cooler.It looks like there is a drilling required in the crossmember.
  • AndyP
    • 6049
    I have the Wagner intercooler fitted on a 3B crossmember and I don't remember having to do an drilling to fit it. I'll see if I can find a picture.
    • AndyP
      • 6049
      you can just see the brkt here.
      Does yours look like this?
      • piotr
        • Jul 2012
        • 1470
        Great help from you Andy.it looks like it will need drilling through ,to attach the bracket to the crossmember isn't it?
        • piotr
          • Jul 2012
          • 1470
          It looks like the oryginal bracket on the left hand side of crossmember (the one with two holes in where you bolt on the cooler)need to be cutted off as it's in the way,there is no way to fit the new intercooler with that bracket in place
          • montyrs2
            • May 2008
            • 522
            I had to drill mine on an ABY
            • kinaputt
              • Jan 2012
              • 285
              • Country: Norway
              You have to drill holes or use self tapping screws. Its only bolt-on for ADU crossmember (RS2)
              • piotr
                • Jul 2012
                • 1470
                • piotr
                  • Jul 2012
                  • 1470
                  What about other side of intercooler?Is it just held by the silicon hose?As original alan bolt is now miles away
                  • piotr
                    • Jul 2012
                    • 1470
                    Fitted
