Garrett Gtx30 Oil restrictor or not
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    Hello
    Just bought a 3076 gen 2 for the s2
    But im in doubt if I should use a 0.030 0.040 or none at all?
    They say it has one from factory but I sent that to big ? It's 3 mm
    Garrett says
    "An oil restrictor is recommended for optimal performance with ball bearing turbochargers. Oil pressure of 40 - 45 psi at maximum engine speed is recommended to prevent damage to the turbocharger's internals. In order to achieve this pressure, a restrictor with a 0.040' orifice will normally suffice, but you should always verify the oil pressure entering the turbo after the restrictor in insure that the components are functioning properly. Recommended oil feed is -3AN or -4AN line or hose/tubing with a similar ID. As always, use an oil filter that meets or exceeds the OEM specifications. "
    "OIL LEAKAGE SHOULD NOT OCCUR ON A PROPERLY FUNCTIONING SYSTEM IF RESTRICTOR IS NOT USED UNLESS THE SYSTEM PRESSURE IS EXCESSIVELY HIGH. "
  • Laaf
    • Oct 2010
    • 275
    You should use an restrictor, I've got this one;
    • s2dk
      • Jul 2016
      • 507
      • Country: Denmark
      They State less than 30 psi But garrett Them self say 40-45
      Hmm. And garrett only recommand it not say it needs to be used
      Hmm
      I know of some that dont uses it
      If its start spitting Oil out the back it Will need one ��
