Low boost - 0.4 bar - likely cause?
  • curlyks2
    • 1069
    Got a problem with my (ABY) S2: low boost pressure of 0.4 bar. No obvious leaks, so my initial thought is knackered N75 WGFV. Anybody got other suggestions/thoughts?
    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
  • LSG
    • May 2010
    • 897
    It could be your multiple function water temperature switch. It,s a common one to half your boost. I would start with that first. It is a few seconds to check just unplug it and pop out for a drive. If your boost is back, happy days. Good luck Lynn.
    • LSG
      • May 2010
      • 897
      Sorry that should have said multifunction water temperature switch. Still I just woke up
      • LHD_Kid
        • May 2006
        • 3695
        I think you'll be right with the WGFV......
        • mike74
          • Apr 2014
          • 615
          ...or the altitude sensor could be misreading...
          • Rikki Kitto
            • Feb 2010
            • 6276
            Had this a few weeks back and it was the MFTS
            • curlyks2
              • 1069
              We have winners MFTS replaced and full boost is back.
              • RS2junkie
                • Mar 2011
                • 409
                • Home: Ireland Current: Bahrain
                I had exactly the same thing. When you replaced it, did you notice any change in where your temp gauge normal sits at.. before it was rare to se it above 90, now my new normal is 92+ ? In the photo this is where the fan comes on, before it would come on at just over 90 ?
                Is this normal or could there be different spec of MFTSs ?
                Have you noticed a change ??
                Paul
                • curlyks2
                  • 1069
                  Paul
                  Yes. Exactly the same change as you. Previously fan would keep the temps around the 90 mark (plus/minus a mark either way), now it's a couple of marks higher. I guess it's a slightly different spec - which isn't a surprise given that the original/old ones were a four pin design, whereas the modern replacements are three pin.
                  • Rikki Kitto
                    • Feb 2010
                    • 6276
                    Paul
                    Mine sits a few mm higher now but all works fine
