Just found this info while sorting my old downloads directory:
Sau
[- CUT HERE -]
below is the bosch part number list for the rr motor ur-quattro 20v. i'm
posting it for the archives, and for those with the 3b (usa) motor. this
information is from bosch.
dave
'95 rs2
'90 ur-q
BOSCH VEHICLE INFO
Brand AUDI
Model Quattro 2.2
Manufacturer's model series -
Manufacturer's designation 85
Manufactured in D
Country versions for -
Vehicle type Coupé, all-wheel drive
Year of manufacture 08.89 - 07.91
KBA code (D) 0588 479
Bosch vehicle no. AUD 335
Engine type Spark-ignition engine, Supercharged
Engine type RR
Engine designation -
Swept volume 2,2 Litre (2,226 cm3)
Power 162 kW
Cylinder 5
Vehicle voltage 12 V
Systems: Engine
Engine Control (BOSCH) Motronic M 2.3
Bodywork
Instrumentation (BOSCH) Cockpit instrument
Suspension
Anti-skid system ABS
BOSCH EQUIPMENT
Vehicle: AUDI/Quattro 2.2 / <85> / 08.89 - 07.91
Manufactured in; D
Swept volume / Power: 2,2 Litre / 162 kW / 5 Cylinder
Engine type: RR
Bosch vehicle number: AUD 335 KBA code (D): 0588479
Equipment: Complete equipment (Total)
Product From-to Info Part Number
ENGINE
Ignition
Breakerless ignition distributor (JH 5) 0 237 522
019 H
020 E
Knock sensor KZB 0 261 231 036 H
Knock sensor KZB 0 261 231 037 E
Knock sensor KZG 0 261 231 038 H
Knock sensor KZG 0 261 231 039 E
Spark plug, Super (F 5 DP 0 R) PSE 0,60 mm * 0 241 245
641
Power supply / Starting System
Alternator (N1 14V 34/90A) 90A 0 120 469 822 H
Alternator (N1 R 14V 34/90A) 90A 0 120 469 888 E
V-belt; open-flank toothed(13x950) FKL 1 987 947
615 O
V-belt; open-flank toothed(10x825) GEN 1 987 947
605 O
Starting motor (DW R 12V 1,4 kW)
Fg Number: » 85-L-000-400 » 12.89 0
001 108 072 H
- Service part product 0 986 012 320
- Service part product 0 986 012 321
001 108 073 E
Fg Number: 85-L-000-401 » 12.89 »
0 001 108 101 H
0 001 108 102 E
Fuel / Air System
Control unit, Jetronic / Motronic (M 2.3) 0
261 200 453 H
261 200 454 E
Air-mass sensor, Jetronic 0 280 213 007 H
Air-mass sensor, Jetronic 0 280 213 008 E
Pressure regulator, Jetronic / Motronic 0 280 160
234 H
279 E
Idle-speed actuator 0 280 140 512 H
Idle-speed actuator 0 280 140 513 E
Temperature sensor, coolant Jetronic 0 280 130
037 H
038 E
Lambda sensor » 07.90 0 258 003 957 H
Lambda sensor » 07.90 0 258 003 057 E
Lambda sensor 08.90 » 0 258 003 234 H
Lambda sensor 08.90 » 0 258 003 235 E
Fuel-injection valve, gasoline 0 280 150 737 H
Fuel-injection valve, gasoline 0 280 150 738 E
Cutoff valve 0 280 142 106 H
Cutoff valve 0 280 142 107 E
Canister-purge valve 0 280 142 155 H
Canister-purge valve 0 280 142 152 E
Throttle-valve position sensor 0 280 120 410 H
Throttle-valve position sensor 0 280 120 411 E
Electric fuel pump, gasoline 0 580 254 921 H
Electric fuel pump, gasoline 0 580 254 922 E
Electric fuel pump, gasoline WW 0 580 254 910
Fuel filter, Jetronic * 0 450 905 133 H
Fuel filter, Jetronic * 0 450 905 134 E
Lubrication
Lube oil filter * 0 451 103 225 O
Cooling system
Motor, radiator blower 0 130 109 224
Mechanical Components
Toothed belt 1 987 949 141 O
BODYWORK
Wiper / Cleaning Installation
Wiper motor, complete (WSA) LLE # 0 391 000 151
Wiper motor » 06.89 LLE 0 390 241 095
Wiper arm, left LLE 3 398 102 191 H
Wiper arm, right LLE 3 398 102 190 H
Wiper arm, left LLE 3 398 102 165 E
Wiper arm, right LLE 3 998 102 164 E
Wiper blade LLE 3 397 110 715
Wiper blade (spoiler) LLE 3 397 001 422
Wiper blade RLE 3 397 110 837
Wiper blade (spoiler) RLE 3 397 001 417
Rear wiper system, complete (HRA) # 0 392 810
019 E
Rear wiper blade 3 397 012 509
Electrical installation
Warning / Turn signal flasher » 07.90 0 335 200 038 O
Warning / Turn signal flasher ANB 0 335 200 041 O
SUSPENSION
Braking System / ABS
Disk-brake pad set; front * 0 986 461 115 O
Disk-brake pad set; rear * 0 986 491 441 O
Brake disk, front 0 986 478 229 O
ABS-control unit (ABS 2 B 2) 0 265 103 021 H
ABS-control unit (ABS 2 B 2) 0 265 103 020 E
ABS-hydraulic modulator 0 265 200 012 H
ABS-hydraulic modulator 0 265 200 010 E
ABS wheel-speed sensor, front 0 265 001 039 H
ABS wheel-speed sensor, front 0 265 001 040 E
ABS wheel-speed sensor, rear 0 265 001 062 H
ABS wheel-speed sensor, rear 0 265 001 063 E
MISCELLANEOUS
Wiring Harness Components
Wiring Harness Components # 1 987 352 018
Explanations:
90A 90 amperes
ANB For use with trailer
FKL For air conditioner
FG Chassis
GEN For generator operation
KZB Designation: blue
KZG Designation: green
LLE For l.h. drive
PSE Special platinum electrode
RLE For r.h. drive
WW By choice
H After market equipment
E Original equipment
* With illustration
O Original equipment not supplied by Bosch
# Not for delivery - only for indication of service parts.
Sau
[- CUT HERE -]
dave
'95 rs2
'90 ur-q
BOSCH VEHICLE INFO
Brand AUDI
Model Quattro 2.2
Manufactured in D
Engine type RR
Power 162 kW
Cylinder 5
Systems: Engine
Bodywork
Suspension
BOSCH EQUIPMENT
Manufactured in; D
Engine type: RR
ENGINE
Ignition
019 H
020 E
641
615 O
605 O
001 108 072 H
001 108 073 E
0 001 108 101 H
0 001 108 102 E
Fuel / Air System
261 200 453 H
261 200 454 E
234 H
279 E
037 H
038 E
Lubrication
Cooling system
BODYWORK
019 E
SUSPENSION
MISCELLANEOUS
Explanations:
90A 90 amperes
FG Chassis
LLE For l.h. drive
RLE For r.h. drive
WW By choice
* With illustration
