An ABY engine doesn't have plugs leads. It has the coil packs attached to the back of the metal cover instead. Has your engine got a dizzy?
It also shouldn't have ABY on the head as the the engine number is on the block. As Jamo says can you take a pic of the engine or failing that I should be able to come over and see you at some point as your not far down the road.
My Avant is an ABY so you will be able to see the differences. Beeties coupe has a bit of a hybrid engine with an AAN bottom end and a 3B head. It will work no problem but is a different setup.
Ben
Take it we're not going to check out your hairdressers car then, Beetie?
If you want I can pop over to Sapcote over the weekend. I'll need to fill up at some point and Sutton Elms is the nearest Shell station so I'll only be round the corner.
I'll PM my number (beginning to sound like some kind of dating meassgeboard this )
Ben
