V10 engine dimensions
  • vidar skotheim
    • Apr 2005
    • 566
    • Country: Norway
    Anyone knowe engine dimensions on the rs6 v10 engine (s8/s6/r8)
    Lenght should be close to the aan engine ?
    Will it fit in a older s6/rs6 c5 ?
  • varia
    • 821
    • Current: United States
    i can measure an r8 v10 for you, if that works
    • V6quattro
      • Sep 2008
      • 949
      I did the measurements to fit the v10 in a B4 chassis last year i dont remember the dimensions on the engine but in the B4 its only possible if you use the new style gearboxes witch moves the engine about 15cm more back.
      I think it will fit the C4 as the old 5 cylinder is longer.
      1360kg/600Whp Avant 0-200km/h 9sec
