S2 stopped on highway - low oil pressure -help needed
  • EvenM
    • Nov 2010
    • 184
    • Home: Sweden Current: Norway
    Hello
    Update: 12/4
    The car does not start, and does not show any faults in vagcom
    My s2 stopped on the highway yesterday. First the red oil light blinked (oil pressure light?) and the car just died.
    Thought maybe it was a oil leak but could not see anything, I put on 1- 2 dl oil, and it started but then stopped again after about 250 meters.
    The engine turns over fine, no knocking noise, but oil pressure on the guage is flipping between 1-2 bar when turning over. It almost fired when I tried after it had stod still for 15 min. Good level with oil on deepstick
    Any Thoughts? Can be oil pressure sensor, but that would not make the ECU stop the car or is it something far more serious?
    Thanks
    Best regards
    Even
  • mike74
    • Apr 2014
    • 615
    Maybe head gasket gone? Can you pull the spark plugs and check for oil in them
    • 220bhp
      • 2578
      • Home: United Kingdom
      Oil cooler leak will dump oil quite quickly .
      • macof
        • Feb 2008
        • 48
        • Country: Slovakia
        Have the same problem. Broken oil pump.
        • EvenM
          • Nov 2010
          • 184
          Will that cause the engine ecu to cut/ shut down the engine ? I think something triggered the ecu to shut down the engine, thats why my first thought were a faulty sensor
          • EvenM
            • Nov 2010
            • 184
            I put on new rs2 head gasket 1,5 years ago. No sign of oil leaks in engine bay or under the car. Can check the plugs anyway
            • mike74
              • Apr 2014
              • 615
              Was just thinking that oil soaked plugs wouldn't fire so could explain loss of oil + not running. If sudden loss of oil pressure (for whatever reason) then wouldn't you hear the bottom end knocking?
              • rustybullethole
                • Aug 2013
                • 531
                Im sure the ECU looks for initial oil pressure to give permissive to start engine or am I dreaming?
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  Nope! You can run the engine without oil pressure until destruction!!
                  I think is something electric.
                  • Henkjan
                    • 1705
                    what fault codes did you see ?
                    • EvenM
                      • Nov 2010
                      • 184
                      Pulled the codes today, none regarding this issue.
                      After that I turned the engine, it started, and the oil pressure boosted right up to 5 bar on the guage in the car. So everything seems normal again, weird...
                      So I think it have to be a electronic fault.. Always something after winter storage
                      • Rikki Kitto
                        • Feb 2010
                        • 6276
                        I know this for a fact
                        • EvenM
                          • Nov 2010
                          • 184
                          Not good
                          • EvenM
                            • Nov 2010
                            • 184
                            Any suggestion to what kind of electronic fault that can stop the car while running when the oil pressure light comes on?
                            • mackenzie50
                              • Mar 2010
                              • 740
                              So Always something after winter storage
                              oh yes indeed...or just a few weeks of inactivity- had a bit of drama getting mine to fire up again this week...thankfully it did eventually.
                              Good luck with finding your issue
