So I'm going to change the timing belt on my 7A quite soon and I want to make sure I don't think afterwards, "damn, I wish I had done X, Y and Z at the same time". I want to make sure that the engine is running well before i plough on with cosmetic issues and lowering it etc.
Things I have...
Timing belt kit inc Water pump and Pulley
New radiator (after wasting money buying a "new, unused" radiator from a forum member that actually leaks. the radiator leaks. I don't know if the forum member leaks)
Rocker cover gasket
exhaust manifold gaskets
I need a VAG 2084 crank lock tool. Best price I can see is from Germany. €35 plus €15 delivery here.
I'll need threadlock (need to check if I have that already)
What else do I need or should I be thinking about doing at the same time as an uber-service? Clean/replace the injectors?
Any recommendations for HT leads, dizzy cap and rotor arm? Or just get dealer parts?
I don't have a manual so I'm planning to use various guides I've found online, such as these
All input welcome.
Things I have...
Rocker cover gasket
All input welcome.
What it means is that the contact surface of the bolt head should have a light coating of sealing paste applied to it. HTH.
