Hey guys!
Im having a big issue with the car atm after its been idling for 10mins or so. The problem is that it starts to go bad and almost chokes itself. I then discovered the charcoal filter began to overflow with gasoline. My next action was then to unscrew the fuelcap and then i discovered alot of vapors were trapped inside as my hair was nearly blown off
I then checked to see if the engine sucked vacuum from the charcoal filter, but it sucked just fine. Im now outa thoughts, but having in mind if it could be something blocking the system ?
any guesses ?
Best regards!
any guesses ?
Best regards!
