Cold start rattle ?
If it goes away, then most likely it's the tappet noise. It could be worn tappets, bad block check valve (oil flows from the head to the oil pan when the car is off), oil too thin, bad oil pressure.Comment
About the same as mine.
Change the tappets then. They're not expensive. I bought a full set of INA hydrotappets for ~60 euros.Comment
Old, tired hydraulic lifters can leak down when the motor is left overnight. Replacing them or disassembly and cleaning will sort any problems with leak down. Based on the cost of replacing them, I'd replace before cleaning 20 of them. BTDT.91 Modded 3B
14 A6 Avant Black EditionComment
Hehe Yah thinking Thats my problem. But Allso want new jonus cams in at the same time bit have to get the cams first
I found some lifters on here. Autopartsmarket.eu. There the lofter are 4 euro a piece
Any other place they are 7 euro both Said to be ina
Im like how Can it be that much cheaper are they fake ina lifters?Comment
Haven't seen such a thing as "fake" INA lifters. Been buying these for many cars and all have been cheap & working great.
You have a very large overpricing on yours. Thing is, I have 44% off on all car parts in that shop, hence I can get many & many parts really cheap. They cost 5.84 eur a piece if looking at a standard price, so not far from the price you're seeing.
I can even get a +0.5 oversize INA lifters from there, but those do cost a fortune.Comment
Yah they have the oversize one But Why go for that one ? What should That do better ?
So it safe to say that i Could Buy the lifters here and save a lot vs eBay or autopartshop.co.uk
... At our local shop, 3.27 eur a piece...
