G69 Throttle Sensor code 00518 sporadic open short circuit to positive
  • seanfillingham
    • Jun 2016
    • 37
    Hi.
    having this code come up.
    I can clear it ok.
    Tried another sensor no joy.
    Been through the trouble shooting guide and resistances are fine and expected voltages.
    So struggling with it.
    No boost and like limp mode.
    Anyone had this?
    Ta
    Sean
    Sent from my SM-G925F using Tapatalk
    Most likely a problem with the connector. Check the pins in the harness connector. Sometimes they get pushed back. Also you can check the G69 using this test sheet:
    G69 info: http://forums.quattroworld.com/s4s6/msgs/20405.phtml
    • seanfillingham
      • Jun 2016
      • 37
      Ta for that.
      I had used the sheet but will check it all again 🙄
