Weird issue that has developed over the past few months.
Car smells of fuel inside the cabin when left overnight as well as when driving at small speeds with the windows open.
Weirdly enough when the car is in the closed garage it doesn't smell outside, but mainly inside the cabin.
So far changed or checked:
N80 valve in operation with vems
New carbon canister
Fuel lines and fume lines
Adjusted tank cap and seal from the trunk
There is no pressure escaping from the tank when opening the cap to fill the tank
I cannot see any leaks from anywhere from the engine bay and under the car.
I will be checking the valve under the canister in case there is an issue with that although visually nothing was broken.
Anything else I should check?
New carbon canister
