Catcams advice
  • s2dk
    • Jul 2016
    • 507
    • Country: Denmark
    Catcams advice
    Hello
    Was looking to get som catcams for my engine
    And had one of these in mind
    1012339
    Or 1012335 (needs catcams springs )
    Wich one would you go for and Why ?
    I wasent going to pull the head right now for changeing springs But If its the Best option
    I Could go that Way and just Do the change without talking it off
    But is it Worth it?
    Im not going past 7500-7800 rpm anyways.
    Its a Daily street car
    AIM around 600 HP
    Turbo is a Gtx 3076 gen2 ar 0.82
    Engine is Stock except rods
    Stock head (porting later)
    Turbulant tube em
    Furans Im
    Treadstone ic tr1045
    70 mm tb
    Cams has adjusteble chain sprockets. And there Will be a adjusteble cam wheel from catcams on
    Hope some of you have some advice
    Thx
  • diesel des
    • 3896
    7a cans might be a better compromise and cheaper?
    Sent from my Moto G (5) using Tapatalk
    • PRY4SNO
      • 767
      Agreed.
      2013 Touareg TDI /// #farmenwagen
      • s2dk
        • Jul 2016
        • 507
        • Country: Denmark
        Maybe But dont want 7a cams ��
        • diesel des
          • 3896
          Why? Just to be different or some other reason
          • s2dk
            • Jul 2016
            • 507
            • Country: Denmark
            i want a set of new cams. not some old once i cant see if they are worn to junk conditions and allso you get the sprocket for adjusting timing with the cat cams. you need to buy that allso and then there is not that big of a price difference in the end
            • diesel des
              • 3896
              Ok I understand. I don't think our engines are known to wear out cams often? Maybe I'm wrong on that?
              • s2dk
                • Jul 2016
                • 507
                • Country: Denmark
                I dont Think they are But lets say i find a 7 a cam set with 150-200000 km om Them Think that Will be a realistick nr
                Then Im just thinking they must be just a Little worn
                Maybe just a 10 og a inch Maybe more Maybe less But still worn ?
                • curamrdan
                  • Sep 2014
                  • 91
                  • Country: Czech Republic
                  I would like to point out another thing. Audi engineers design cams as low agressive intake, with "agressive" exhaust. Cat cams tend to be like more "ususal" engine design, more agressive on intake cam and mild exhaust.
                  What work better on your engines and why?
                  • s2dk
                    • Jul 2016
                    • 507
                    • Country: Denmark
                    i dont know anything about that. i just dont want used cams in my engine
                    • curamrdan
                      • Sep 2014
                      • 91
                      It was question to public, not arguing to use something you dont want.
                      Im running PKM motorsport regrind cams, which i find its some catcams naturally aspirated engine - "symetric" (eg both intake and exhaust are the same) profile
                      • s2dk
                        • Jul 2016
                        • 507
                        • Country: Denmark
                        Arh did not catch that Sry ��
                        • mushasho!
                          • Apr 2007
                          • 163
                          Regrind from 7A?
                          _RubĂ­_
