What injectors?
  • Monkeymagic
    • Mar 2012
    • 3419
    What injectors?
    Im set to replace the injector seats in my 3B coupe. Im thinking its probably wise to replace upgrade the original injectors. What is best to use. Part number etc? Many thanks in advance.
  • Monkeymagic
    • Mar 2012
    • 3419
    http://m.ebay.co.uk/itm/5x-Siemens-D...%257Ciid%253A3
    What about these?
    • Colesy
      • Feb 2009
      • 2980
      If you change the injectors for anything other than the same spec you have fitted then you'll need a remap. It might be worth having them cleaned and flow tested but they're not really worth replacing unless completely necessary.
      • LHD_Kid
        • May 2006
        • 3695
        Are you re-mapping?
        No?
        Then why not just get your 3B ones professionally cleaned and flow tested?
        • Monkeymagic
          • Mar 2012
          • 3419
          Ok ill lool at clean and new seals. No im not remapping. Im quite happy with the power and reliability .. ive cursed it now
          • stocious
            • Jul 2012
            • 838
            Look for a place with a ASNU machine for cleaning
            1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
            • Monkeymagic
              • Mar 2012
              • 3419
              Excellent cheers.
