It not mine I need to measure I am looking for a suitable replacement and need to know lengths of others for example....AAN would be helpful.... as I cannot source the correct one
I am not about to send it to Australia to be repaired.... look mate you are not really helping....
I just need some kind forum member to give me some info..... Then I might be able to buy one of the shelf.... I just wanted to have a idea before I order
well i cant say what region your in but if you google yourself in your native language you will find one. why dont you try and hive yourself some effort.
I just measured my RHD aby one and including the plastic spring mounting on the end it comes out at 1056mm
Thank you.... bertman
Its a start, what I would like if someone is so kind is the length of a AAN LHD cable casing and inner.... as I can get one of the shelf and it probably the closest
Mate.... Why do you not go and help some other member and leave this thread a lone....
