Coding plug ??
  • zlobo
    • 967
    Coding plug ??
    i am vondering what the Coding plug is?
    and what do it do,and where is it located?
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Territory details unknown.
    SS
    • zlobo
      • 967
      yea that i know.. hmm
      kostic.nu
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Maybe Audi don't know. Just some leftovers they didn't what to do with!
        SS
        • zlobo
          • 967
          dont think so i was looking at the shematics rigt now and located it,, its connected to the instrument its a 6 pin connector. i have to check that tomorrow morning on my car.
          kostic.nu
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            Good luck in tracing them.
            SS
            • pastures16
              • 2058
              lol zlobo this is your coding plug
              http://www.s2central.net/autocheck_04.html
              94 s2 avant
              aoc member 1116
              • 4WheelDrifter
                • Oct 2004
                • 5773
                • Country: Devon
                Get on! Good work. All the info is there. You just need to know where to look.
                SS
                • zlobo
                  • 967
                  hmm are you shure?? its not a 6 pin connector as it says in the shematics..
                  kostic.nu
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    Carry on with your investigation Zlobo. See if you can solve this one.
                    SS
                    • zlobo
                      • 967
                      1rst thing in the morning i am going to check this out... and now i am going to sleap
                      kostic.nu
                      • zlobo
                        • 967
                        This morning i checked it out.. .and there was no 6pin plug in the instrument cluster..
                        I am going to chek more this weakend.. By the way wnere is f96 (altitude sensor) located?? it says near the ecu but where???
                        kostic.nu
                          The coding plug is only used in some territories for various purposes. It can be used for maximum speed limiting on an RS2 for example and S4/S6's that were exported to North America.
                          Never tried messing with the code plug on a 3B or ABY - they are just empty on UK cars, so the ECU reads it as code=1. From memory a code=4 is the speed limiter plug.
                          The coding plug itself resides near the ECU in that footwell area.
                          Paul
                            F96 is located behind the trim panel at bottom of A-pillar on passenger side. Just above the moisture trap for the ECU vacuum/boost hose...
                            Paul
                            • zlobo
                              • 967
                              ok. then i know the plug is located about 30cm from the ecu connector.
                              and its a bridge (no electronic). Thanks Paul. you saved me some time..
                              kostic.nu
