hello, i would like to know if anyone has any knowledge on S2 crankshafts. i need a new crank for my 3B S2 as it is not repairable due to excessive wear on number 5 journal and damage to keyway. Is the audi 200 turbo crank the same, if not what other cranks will fit this engine?
also found that distributor was off a 1985 naturally aspirated audi coupe what other cars had the same distributor?
any help would be much appreciated,
regards,
louis
regards,
louis
