Split plastic
  • Dave
    • 58
    Split plastic
    Does anyone know if the moulded black plastic bit at the top of the main radiator is a separate item or do you have to order the whole radiator.
    One of the pipe connections has split and left about 1.5cm of plastic protuding to connect to the main hose.
    Once again this problem arose when visiting Manchester and I live in Lincoln.
    Suggestions?
    Dave
    '93 ABY coupe
  • porkkis
    • 1994
    It's part of the rad. Sorry.
    • Dave
      • 58
      What sort of pressure does the coolant run at, I can get the hose connected to the remaining bit of plastic but willl it do me a 125 mile journey?
      Would superglue be the way forward?
      Dave
      '93 ABY coupe
        New rad time mate unfortunately.
        • jade
          • Jan 2005
          • 1811
          I have a split rad at the top by the bleed screw , have been waiting to change rad
          repaired mine with G 5 west apoxy (5 min apoxy ) It s been holding for 6 mouths
          RS 2 580HP
