I was hoping anyone could give me some ideas. I'm not getting a spark, the motor turns over strong. I have check the plug connector to the ignition coil and its seams fine then I picked up a new coil and swapped them out and nothing. I took of the wire to the coil and tried to get it to jump a spark and nothing. I tried to get it to spark to the distributor should I have tried off the block?
Another problem, the fuse to my Clock, Accessories and luggage lights keeps blowing. When I plug a new one in it lights up and blows instantly. I don't see how this could effect the car from not starting but should this be sorted out first?
Thanx
Andrew
Thanx
Andrew
, The speedometer doesn't work and the central locking doesn't work now.
