7A to 3B head
  • WabTheKing
    • May 2004
    • 2567
    7A to 3B head
    only differance i can see is the water manifold,
    this looks like it could be machine fairly easyly
    anyone done this?
  • caterpillar
    • 2480
    same casting nr....it will fit,and easy to machine the water manifoil.....
    • PeterS
      • 423
      Gents:
      This is exactly what Javad did on his 80tq.
      -Peter
      Peter S
      1990 ErsatzS2 - track toy
      1991 Coupe Quattro
      1991 Coupe Quattro
      1995 S6 Sedan
      1995 S6 Wagon
      • ~Delta
        • Apr 2005
        • 797
        ...3B cylinder head also has extra exhaust manifold studs.
        Never show a fool a half built house.
        Never underestimate the power of stupid people in large groups.
        Life is like a **** sandwich
        The more bread you have, the less **** you eat
        • spink
          • 4382
          I was stripping a 7A head earlier and could only find the intake side to be different, exhaust side is identical.I heard someone say that 7A's dont have sodium valves but i cant be sure.You can see the difference here 3b is the clean one.
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            AFAIK 7As DO have sodium filled exhaust valves.
            SS
            • pastures16
              • 2058
              ill 2nd that hows your hangover 4wd
              94 s2 avant
              aoc member 1116
              • Josh-stateside
                • 741
                On the matter of exhaust manifold studs. The 7a engines with cast exhaust manifolds came with as many studs as the 20vT heads. The 7a engines with tubular heads came with less.
                ttyl
                Josh
