Cylinderhead bolts
  • Jeffer
    • 2057
    Cylinderhead bolts
    I'm soon going to reassamble my 3B engine, and first of all I'd like to know "if" I need to replace them? And if so, is there an upgrade for those bolts, instead of the original. And maybe better priced then VAG bolts.
    Greets,
    Jeffer
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    Yes - they are stretch bolts and must be replaced. When buying a set - make sure and get all the same strength bolts as a mixed batch could lead to problems.
    Paul
    • porkkis
      • 1994
      Yes, renewal of the bolts is a must.
      I ordered a set of Reinz bolts and you should be able to order them too via some 3 party spare part dealer. Reinz bolt set number is 14-32049-01 and the price is around 70e (~£45 inc vat).
      When building a high power engine (>350hp) it might be a wise decision to go for studs and at least Raceware and ARP manufacture a set for the 20V fiver.
      Latter ones are probably easy to purchase from some usa-car performance shop.
      I've hear some rumors that ARP set includes a bit too small washers and some people use SportQuattro washers with their ARP set. P/N for the SPQ washers is 035 103 377. Martyn or someone could probably tell the price for those but they surely are not cheap for washers
      • Jeffer
        • 2057
        Thats what I need
        Thanks man, I'm going to look in that.
        High Octane website
        • desmo888
          • Oct 2003
          • 390
          I'd be happy to help if you need anything for the U.S.
          There are several Hi performance catalogs but not sure if they ship overseas.
          www.jegs.com
          I know that even if they do not list a particular part, as long as they handle that line, they will get you anything you want (at a great price).
          desmo888@comcast.net
          Dave K.
          USA
          1991 e//S2 (home built S2 - the only way to get one in USA!)
          2001 S4
          • porkkis
            • 1994
            Originally posted by Jeffer
            Thats what I need
            You're welcome.
            And if you are interested what's wrong with the arp washers is that they are too small diameter and tend to sink in the "soft" aluminium head and then the head gasket starts to leak...
            • audiman
              • 4827
              give vag parts a ring. Thats where my bolts came from. But be warned there are two bolts using the same part number!!
              One is 10.9 tensile and the other is 12.9 tensile (these are the ones you want). Martyn will know this anyway. Cant remember how much, as i never asked
              Tom C - www.rcmr.co.uk
              Audi UR Quattro
              Audi 100 C3 2.0 5 cyl 115ps
              Audi B5 RS4 645ps 911nm
              • Martynf
                • 1885
                The washers are £2.59 from us.
                Stock OE head bolts are £2.86 each.
                Martyn
                Martyn
                www.vagparts.com
                • SteveH
                  • 4460
                  Guys,
                  I'm just about to buy a set of ARP bolts, drop me a PM if you're going the same way too. I can get a few quid off If I order more than one set
                  If there are 5 or more people interested the price will drop again
                  A must if you're planning on taking the head off more than once.
                  91 Modded 3B
                  14 A6 Avant Black Edition
                  • porkkis
                    • 1994
                    Steve: Buy the washers from Martyn. Don't use the ARP ones. You have been warned.
                    • SteveH
                      • 4460
                      Thanks Porkkis
                      I'll work out a price for the ARP bolts + washers. It may be cheaper to go for the Raceware bolts instead.
                      91 Modded 3B
