i think my tcp pump is death. when i turned ignition key on (not start engine), i cant hear any sound from tcp and when i put hand on it and my friend turned ignition on i cant fell any noise from tcp. what could be cause of it? Is possible i have problems with any sensors or wirings? Can i cause any damage on my car ? (it is very cold in my countr now)
grega
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
I found out that volvo use the bosch turbo coolant pumps identical to ours and that they are about 45 quid all in from volvo, might be worth investigating.
Graham
thanks for all infos about tcp.
i want to ask you if it is possible i have some gizmos in electronic system? sometimes when i started my car my radiator fan at once start working at speed two. (my car has AC) I wonder if it is wrong? and if it is connected to problems with TCP somehow:confused:
grega
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
If your rad fans comes on when you start the car, you probably had the AC turned on then!! as soon as you turn on the Ac, the rad fan comes on straight away!! try it...
martyn it wont work like you decribe it. Nomether if i have AC (i mean clima it has symbol like crystal) on or off radiator fan works when i strat engine. But if i shut down AC completly radator fun dont run.
Any new ideas abou that m8es??!
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
