Anyone of you guys got the part number for the engine temperature sender that's located on the back of the engine, just below throttle body/ISV etc?
I've looked in the family album but can't seem to find it. Vag-com session on Sunday pulled up G62 - engine temperature sender when we dumped codes.
I've noticed the last week or so that the engine coolant temp getting way past where it used to be on the gauge before the fan cuts in. (fan now cuts in when needle is half way between 90 and 120
) This seems the likely cause.
Thanks in advance
Jas
) This seems the likely cause.Thanks in advance
Jas
New MFTS is not so complicated and does not need +12V. Ground is the coolant manifold.
