Been thinking about this over winter, as I could do with a bit more grunt and a bit less understeer
I have a 10V 90Q Saloon and was thinking of swapping out the 130hp 5pot for a 20v 4pot from an A4, either NA on Throttlebodies (190Hp with some port work) or Turbo on a Full Pectel ECU...300hp+
Either will be a Lot lighter than the current boat anchor, helping both the Power to weight ratio and the Handling balance.
Anyone seen it done ? got any Ideas ? or Starting points (Which model to get donor from for ease of Transplant)
As always, all help gratefully recieved
Dom
Dom
) and a 4pot 20v would give more power and less weight, a 20vt would be even more power and less weight but a lot more cost
