There are a couple PDF files out there which tells OEM turbo applications.http://www.gikturbo.se/prislistor/latta.pdf
S4 owner: Will a KKK K26 bolt up to the RS2 EM? Also will there be any performance..
I chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro? -
I chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Comment
The pictures in ebay are not backwards btw.. My eye's were playing tricks on me, however the cold side housing is definately point in the wrong position.
For anyone curious.
JoshI chose not to choose life: I chose something else. And the reasons? There are no reasons. Who need reasons when you've got quattro?Comment
Josh, sorry for sounding contradictive, but if you look carefully on the type plate of the turbo, the "ausführungsnummer" (or AUSF. NR.) of the turbo is "5326 970 64xx", which means that according to SJM's compressor maps, its cold side is the same one as the old Audi 200 turbo 10v with 165 or 200 HP (Europe only). That cold side flows a bit more air than a K24 7000 but not very much more, and the lag that the hot side induces makes it a really bad trade-off for the stock K24, a stock K24 makes thrust from 2300 RPM-on, being limited at the top end to about 290 HP, whereas the K26 starts pulling at 3300 RPM (with some serious sacrifices in terms of fuel mixture before the turbo starts spooling) and could only give some 305-maybe 310 HP running 1.4 Bar at 6000 RPM, past its efficiency range and minimizing its long term reliability.
A K2670 is a good turbo, I had nearly bought a brand new cold side a few months ago but missed on it at the last minute, but the turbo in this auction simply isn't a K2670 but a K2664
Cheers all,
Mihnea'98 Silver Grey 2.7T S4, dual 2.75" turbo back exhaust with no cats, FMIC, BIG injectors, 10 Bar motorsport fuel pump, modded RS4 turbos, tubular exhaust manifolds, custom intakes, RS4 MAF, Bilstein PSS9, H&R ARBs, 19" BBS CH, custom remap, 511 BHP/505ft-lbs
www.MRCTuning.com
info@MRCTuning.com
Workshop DirectionsComment
your right Mihnea..
I was talking to the owner, long story but I don't like him much.
However it's still put together wrong which through me off.
Btw.. I sent you a private message.
