Help!!!
  • WabTheKing
    • May 2004
    • 2567
    Help!!!
    7A with no spark
    dizzy changed
    metal dizzy sprocket
    ecu changed
    timming sensors checked/changed
    fuses checked
    coil changed
    any ideas?
    had this problem a couple of weeks ago and we thought we has solved it with the timming sensors but its happened again - poss an earth or a relay gone?
    this is really doing my head in now please help!!!!!!
    regards
    will
  • WabTheKing
    • May 2004
    • 2567
    H E L P !
    • quattronutter
      • Jan 2005
      • 690
      do you have live at the coil,carbon brush in the dizzy cap?assuming its the old one that is,check all the engine earths as well,iv had similar problems with 16v golfs,turned out to be crappy earth causing problems..
      • quattronutter
        • Jan 2005
        • 690
        other possibility is the woodruff key has sheared off the crank pulley causing timing problems
        • WabTheKing
          • May 2004
          • 2567
          where abouts are the differnt earths?
          ive checked the ones just above the fuel pressure reg?
          going to check the browns at the ecu end
          • PeterS
            • 425
            Will:
            How did you check the position of the distributor and ensure that its aligned to #1 TDC ?
            -Peter
            Peter S
            1990 ErsatzS2 - track toy
            1991 Coupe Quattro
            1991 Coupe Quattro
            1995 S6 Sedan
            1995 S6 Wagon
            • WabTheKing
              • May 2004
              • 2567
              little dot on the top pully with arrow, line on the rotating part of the dizzy with the line on the outer casing
              • martinjs
                • 3205
                Did you check timing marks on flywheel and crank pulley also? Is there any signal leaving the coil?
                • PeterS
                  • 425
                  Will:
                  first try moving the distributor a "hair" clockwise, try it, then a "hair" anti clockwise and try it again.
                  next thing is to ensure that the cam and crank timing are correct:
                  - does the "0" on the flywheel line up with the edge of the bell housing? Look into the port under the under the dist, near the crank breather.
                  -Peter
                  Peter S
                  1991 Coupe Quattro
                  1991 Coupe Quattro
                  1995 S6 Sedan
                  1995 S6 Wagon
                  • caterpillar
                    • 2480
                    the ignition switch may gone BAD....check the coil,you shall have 12v min on the coil. then you may have bad earth from the engine to bat,or chassi...
                    • porkkis
                      • 1994
                      And even the 62 degree pin on the flywheel may have been litterally fallen off. This is rare, but possible!
                      Take out the starter and inspect that the pin is there.
                      • pastures16
                        • 2058
                        have you checked the hall sensor common problem
                        94 s2 avant
                        aoc member 1116
                        • WabTheKing
                          • May 2004
                          • 2567
                          checked this one as that popped into my mind
                          • WabTheKing
                            • May 2004
                            • 2567
                            yep 12v over the coil but no sparky sparky
                            • WabTheKing
                              • May 2004
                              • 2567
                              yep changed the complete dizzy for the one out of my car which we know works
