This damn car is still running like a bag of turd. WGFV has been replaced today after Royal Mail let me down along with half the country. Selfish gits, thats another story.
The original WGFV didn't work as it was tested on another car. The new one works on this car and mine now does something different. It is not making boost, still only about 0.8 bar with the spring wound in. The WGFV is venting loads of excess boost to intake, so im assuming that its trying to run low boost. No Fault codes are stored in the ECU, which is handy
It feels like you hit the rev limiter but only when the boost goes past 0.6ish bar. this hits in first at about 3k, but if you accel. gently to even 5k and boost it, it does the same. I have NO leaks as all small hoses have been replaced and the others have all been off to check. I have the IC o ring mod and thats ok. DV valve is new. (have gone back to standard setup not atmos.)
PLEASE PLEASE PLEASE help me. Im getting so pissed off. I had a Saxo nail me today and that has pushed me to drinking again tonight. X10
