Mihnea - I need a remap
  • karlblues2
    • Jul 2004
    • 402
    • Home: England Current: Australia
    Apologies for using open forum to contact Mihnea, but PM's appear not to work
    Mihnea, I need an urgent remap on the S2, I need you to advance the timing below 4.5Krpm and keep the timing the same above it where it currently flies and appears fine. This is on the 7% leaner chip labelled 'fuel M03' where the AFR seem ok.
    The car is literally dead below that engine speed, with total lag and it is definitely down to the timing in the chip. Cam timing etc all line up as they should.
    Trust you are well and look forward to your early response.
    Karl
    Oz
    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
    Audi 90 Quattro 20V 1989 7A
    Audi TTRS 2010 APR stage 2 +
    Triumph 675 Street Triple R
  • Sweeper
    • 1317
    • Country: Latvia
    Mihnea , you promised to answer my e-mail in 8 hours . Still no reply.
    Please please please answer. Thanks.
    Vadim.
    • karlblues2
      • Jul 2004
      • 402
      Bump
      • leo
        • Dec 2003
        • 101
        • Country: Poland
        Well, you're not the only one, who's waiting 4 answer. Well... I'm waiting since 2004, march. Do you have so much patience ? :]
        OOOO
        www.AudiKlub.org - the oldest and biggest Audi Club in Poland :thumbs:
          Mihnea is now part of a company called MRC, so guys you can PM or email Doug_RS2 and Lee if you want to book work.
          • Doug_RS2
            • 3847
            Email me.
            Karl - those chips you have are very similar to my brothers car (apness old car). It is not laggy. It definitely sounds like a timing problem - Sal had this exact problem, it flew above 4500rpm and was flat below that. Have you got both cams on their O marks? The correct cam pulley? ANd the crank is on the marks as well?
            Has your turbo ever produced boost below 4500?
            Mihnea is not online in the US so please pm or email me.
            • karlblues2
              • Jul 2004
              • 402
              Thanks Doug
              Will do
              • Tommy200rs
                • 285
                Basic feature with ADU cams and timing is that it kicks hard at 4000-4500 and flies fresh to the limiter and with a tuning chip even better. With rs2 cam settings it is unfare to wait for true kicks below that.
                RS2 cam timing and upgrading ABY to adu has been discussed a lot and there are lots of parts that need to be changed that you have the rs2 specs. Then is that good enough is another thing. Personally I like more the settings with 3B engine inlet cam, NM ex cam in original 3B timing marks and with other full spec direct ignition rs2 hardware including that small rs2 turbo. My subjective comment is based on 1/4 mile end speed 173,6km/h in my heavyweight Audi 200 20v. NM ex cam is far cheaper than the ADU ex cam and you can find used ones from scrapyards.
                With bad cam timing you kill the spirit of the engine. RS2 was originally tuned with high end power in mind ? - kidding though with 315hp high power :-).... but anyhow. Do carefully the cam timing.
                Collected factory 20v cam timing specs are in excel format:
                More ABY cam timing info also here / read in S2 UrSprache:
                habe meinen ABY jetzt weitestgehend auf ADU umgebaut. möchte den umbau natürlich so perfekt und standfest wie möglich gestalten und habe deshalb die Frage in welchen details sich der ADU RS Motor noch von meinem umgebauten ABY unterscheidet... Also habe jetz folgende Teile verbaut: RS2 LLK...
                • karlblues2
                  • Jul 2004
                  • 402
                  Thanks Tommy
                  My S2 has stock ABY cams, RS2 E/M, Green Bosch injectors, Bosch upgraded fuel pump, large FMIC, and a RS2 stage 3 (MD147) Turbo from turbo dynamics.
                  My cam timing appears spot on but I will be rechecking. My question was essentially to find out whether I could, through the ECU remap, advance the timing lower down to reduce the lag or whether I HAD to get NA (7A? cams).
                  Thanks for your threads, I'll have a look at them now
                  Karl
                  Oz
                    Also is it worth having the RS2 intake cam with 7A exhaust?
                    • karlblues2
                      • Jul 2004
                      • 402
                      Tommy
                      I can't access either of those links. They both seem to require login and / or a good grasp of Deutche!
                      Cheers anyway
                      Karl
                      Oz
                        Thought the RS2 intake was the same as the ABY?, they have the same part number on s2central.net
                          I think they are slightly different, ADU has slightly different timing AFAIK
                          • porkkis
                            • 1994
                            The cam itself can be the same as it is. The timing difference is done with the exhaust cam. Cam chain sprocket on the ex cam in a slightly different position and that's all.
                              so is the RS2 intake cam identical to the ABY then?
