Water Leak
  • Nush
    • Apr 2004
    • 33
    Water Leak
    I have an ABY engine and have a serious water leak but can't tell where it's coming from. Have checked all visible pipes around rad etc. It only happens under pressure after the fan cuts in and then can stop as quickly as it started. It is dropping down the side of the sump if that helps? Any ideas before I start stripping it down? Thanks
  • jameswkr
    • 538
    Assuming its not your rad(s) or hoses leaking, your next check is the small coolant pipe sections ( two) underneath the thermostat housing ( on the RH side of the engine as you look at it ). You will need to remove the PAS/Brake pump and the thermo housing. Buy a new thermostat whilst you are in there ( and O ring ). The stealers can sell you offcuts from the "official" hose size or a good motor factors can do it much cheaper. Use the best hose clamps you can find. Getting the hoses on is not funny. Reckon on 3-4 hours for the whole job. Good luck. James.
      Turbo water pipe, Stat Hose or maybe crack in the main rad.
      • Nush
        • Apr 2004
        • 33
        The leak is down the right hand side of the engine so what you suggest makes sense. Thanks alot, I'm going to be busy this weekend...
        • BRY
          • 3755
          Where bouts in Derbyshire are you?
          I had to do this last week and can help you out if you like.
          • NorrS2
            • May 2004
            • 210
            What about the Auxilliary Water Pump? Plastic cylindrical item, sits low down rear of the main Radiator with 3? pipes attached. Mine went and sent water down right (as you look at front of car) side of the Sump.
            Worth a look!
            95 S2 Avant Ming Blue - now gone and sorley missed:cry:
            2001 B5 RS4 Santorin Blue - MRC'd - now here:chit:
            88 Ur MB Quattro -Pearl White - The daddy!:cool:
            Classic S2 Avant billboard ad - "My other car's a Porsche, but today I'm in a hurry"
