You know when you think eveythings going fine, then someone lets you drive their car
and it's a case of mine doesn't do that!
My mate purchased a 1995 S6 slipper waggon last night and being as though he was passing on the way back home he thought he'd pop in. Nice fairly standard green with cream leather, few knocks and clunks, knackered calipers but OK for the £
Anyway he'd driven mine previously to get an idea and hence offered me a drive.
First thing I notice W.T.F. he's getting 2.0bar boost and 2.2 overboost in 4th compared to mine 1.6 and 1.8 overboost in 4th
Mine holds its boost fine just doesn't get that high
He hasn't checked out if someones fiddled with the WG etc. but after a bit investigating on the Forum his figures seem about right and mine are down. Mine has no fault codes showing and I have checked the hoses for leaks, took top of WG and checked seal and valve seems to move freely. Checked vacuum hoses blown off etc. New Forge re-circ valve
I appreciate there could be 101 things, but where do I start, I'm looking at getting an MRC remap soon, so I want to have it running 100% before they start
One small problem I have in addition is sometimes when you pull up to T Lights etc the revs drop low then pick up again, dont know if this is an additional symtom?
On searching for clues WGFV pops up now and then whats this and where do I find it, bit naive I apologise in advance.
Any help much appeciated,
Ben
Ben
. If NOT - find and destroy that boost leak, or anything else, which is not allowing to BOOST
