Cam timing adjustment
  • karlblues2
    • Jul 2004
    • 402
    • Home: England Current: Australia
    OK. Stupid question time. Can anyone tell me what would happen by advancing the cam timing by one tooth on the ABY engine. What is a single tooth worth - is it 5degrees / 15degrees or what? Plus what impact would that have throughout the rev range, low revs through to redline?
    Finally, would a remap be required to compensate for that?
    I am attempting to reduce the lag in the lower end of the rev range Currently everything is spot on factory markings. I am asking Mihnea for a remap anyway to address this low rev range lag (if it's possible), but I was curious as to what impact physically advancing the top cam timing would have.
    Thanks in advance
    Stupid question over.
    Karl
    Oz
    Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
    Audi 90 Quattro 20V 1989 7A
    Audi TTRS 2010 APR stage 2 +
    Triumph 675 Street Triple R
  • Jeffer
    • 2057
    If I think out loud. And I'm no expert in this.
    1 rotation of the camshaft (360 deg.) diveded by 52 tooth on the sprocket = 6,9 degrees. Times 2 (because the cam turns 720 degree on one crank rotation) gives 13,8 degree when you jump one tooth either side.
    360/52=6,9x2=13,8 degree...?
    I think this should be it........But correct me if I'm wrong
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    • karlblues2
      • Jul 2004
      • 402
      Thanks Jeffer
      So what effect will that have on the way the car runs? Will it pull better down low at the expense of higher revs?
      • Jas11n
        • 5067
        Erm, I'm not clued up in any way with stuff like this, but,
        my timing was found to be out 2 teeth advance whilst having timing belt changed on rebuild after I stuffed it.
        I used to have way more lag then my brothers indentical stock 95 ABY.
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
        • karlblues2
          • Jul 2004
          • 402
          Thanks mate
          So that says advance = lag ?? Therefore does back one tooth = less lag?
          Karl
          Oz
          • Uukrul
            • Aug 2004
            • 23
            rather that says factory timing = less lag.
            • BeckyA4
              • Dec 2004
              • 9
              Leave the cams at factory settings!! 13.8 degs is a lot to move a camshaft. If you want to adjust the cam timing then get special pulleys made, then it can be done accurately. What cams have you got??
              1996 A4 1.8T Sport
              Kingfisher Blue MRC Tuned 205BHP
              Mostly good on fuel, expect when driven by Tom :mischeif:
              • BeckyA4
                • Dec 2004
                • 9
                ****** im logged on as Becky
                Tom
                1996 A4 1.8T Sport
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  Sure that's not Becky?
                  SS
                  • karlblues2
                    • Jul 2004
                    • 402
                    Thanks Err Tom, I mean Becky, I mean Tom
                    I have stock ABY cams, and they are set to factory settings, but I am tring to reduce lag by advancing the timing. I want to do it through a remap with Mihnea, but I was asking what impact moving the sprocket would have. Cheers
                    Karl
                    Oz
                    • Doug_RS2
                      • 3847
                      Did you check the cam pulley woodruff key? That was still ok? The timing can still be out with all the marks in the right place if that is broken. It is very common for that to break if the cams are not locked in place when tightening the cam pulley.
                      • karlblues2
                        • Jul 2004
                        • 402
                        Hi Doug. Thanks mate. Can u tell me where I can find the cam pulley woodruff key and how I get to it to check?
                        Karl
                        Oz
                        • Doug_RS2
                          • 3847
                          It is on the cam pulley - the small bit of metal that locates the cam pulley onto the cam. If this has broken then the cam can turn when being tightened and although the marks all line up on the cam, crank, and flywheel - and the 2 cams line up together - it will be out timing wise. I think you have to remove the cam pulley. I will check later if it is visible without removing.
                          I'll take a couple of pics if I can get access.
                          HTH
                          • 4WheelDrifter
                            • Oct 2004
                            • 5773
                            • Country: Devon
                            Hi Karl. HTH.
                            SS
                            • Doug_RS2
                              • 3847
                              that is it - no point in me taking a picture as you cannot see without removing the cam bolt.
