Implications of low compression
  • Alistair C
    • 693
    Looking at high mile S2s, what'd be the implications of the readings being in the region of 8.1 - 9.5 bar - assuming the tests were done properly and on a warm engine?
    cheers!
  • audiman
    • 4827
    Could be worn rings or slightly leaking valves, usually exhaust valves IME. Do a leak down test to find the cause of the problem.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • caterpillar
      • 2480
      you may use some engine oil,bye the sparkplugsholes,2-3 spoons,then you will see about the pistonrings,or the valves...if it is very mutch better komp,its the pistonrings,if not the walves are gone...
      • Alistair C
        • 693
        cheers for the replies guys - unfortunately doing these tests on a prospective purchase is something the AA / RAC don't get involved in - that's be far too useful.
        Further info would be that the car's oil pressure is ~1.0 bar at warm idle.
        Does this tell anything new or just confirms low compression?
        • BRY
          • 3755
          AFAIK this is too low.
          What oil is it running?
          High miles = higher viscosity oil required - 10 minimum i.e. not quanta gold but castrol rs instead
          do a search for oil presure on here and get ready for a long read
          • Beetie
            • Oct 2003
            • 1517
            Dont like mine then?!
            • Chris M
              • Sep 2003
              • 1030
              Should be around 2BAR at warm idle, 1 BAR sounds too low. As said before, could just be crap oil. What is it when its cold??
              Cheers,
              Chris
              Cheers,
              Chris
              Silver S2 Avant : Sold
              • Anees786
                • Jul 2004
                • 85
                What should they read when its cold Does 6 bar sound good
                • audiman
                  • 4827
                  yeah sounds fine
                  Might be that the car is overdue an oil change, old oil tends to give less oil pressure. When my oil is old i get 2 bar warm idle pressure. Thats with new pump and bearings too.
                  Audi UR Quattro
                  • Beetie
                    • Oct 2003
                    • 1517
                    Mines done 130000 and still running on standard oil. No low pressure at all......
