Hi
Need some info on 3b 20v s2?.
What is the capacity oil in lt for the s2 3b, because i have a problem with oil fludding on the turbo can the breather system be responsble for this or what due you suggest.
I have also check the return pipe its open and oil is returning to the sump also brand new k26/27 hybrid.What is the inside diameter for the oil feed to the turbo.
Any help will be apreciated
Thks Chris
Thks Chris
