over boost cut out
  • WabTheKing
    • May 2004
    • 2567
    over boost cut out
    friend of mine has the following problem,
    car is a wr quattro with a 3b engine and rs2 turbo,
    the car usually boosts to about 1.8 bar
    at the moment, you can drive the car normally - no problems
    if you boot it, it reach full boost a couple of times - then the over boost protection cuts in and you have to restart the car to reset it
    told him to clean the connections of the MAF but no differance,
    any ideas?
    cheers
    will
  • S2 Ant
    • 3682
    Boost leak
    Ant
    2011 Kawasaki Z1000
    • WabTheKing
      • May 2004
      • 2567
      not that i can see/hear all the pipes are near enough new
      • Ski
        • 2591
        IC pipe mod thingie?
        ABY Coupe
          Dunno sounds like a mapping issue to me, 1.8bar is quite high a level to acheive if it had a boost leak.
          • WabTheKing
            • May 2004
            • 2567
            wr's/ur's/mb's etc have a differnt intercooler location and dont suffer from this
            cheers
            • WabTheKing
              • May 2004
              • 2567
              its been boosting that much for years so think theres more chance that its a componet thats faulty or dirty
              • Ski
                • 2591
                has he cleaned the MAF connector?
                Maybe its a valve? Im not technical but i had similar issues and it turned out to be some sort of valve near the turbo? (it was jammed open/shut but i cant remember now)
                ABY Coupe
                  Misunderstood what i meant, if it's boosting to 1.8 i doubt it has an air leak.
                  If it only occurs at wide open throttle, then could be ecu mapping issue, ecu fault, maf, throttle sensor etc etc
                  Blocked injector, really is a needle in a haystack guessing on just that info.
                  • DamoM
                    • Feb 2005
                    • 352
                    any ideas?
                    cheers
                    will
                    Did your friend discover the problem on his UR quattro? I have one with a very similar set up and have just experienced an identical problem all of a sudden.
                    *1986 ur quattro,2.5 stroker
                    *1995 Nogaro Blue RS2,Md357
                    *1991 RR 20v quattro
                    *2000 Nogaro Blue RS4,RS6 turbos,tubulars,custom 3" downpipes,Miltek,FMIC,big injectors,RS6 big brakes,RNS-E satnav/TV,592bhp/600lbs
