rs2 ECU vs ABY ecu
  • gavs20v
    • Sep 2004
    • 3057
    rs2 ECU vs ABY ecu
    Can anyone tell me the main differences between the aby and the rs2 ecu? ive been offered an rs2 one and was wondering what benefits this would give me over an aby one with the mods im planning bearing in mind im going to need a remap anyway
    Gav
    S2 Cabriolet.........
  • porkkis
    • 1994
    Nothing really. It only acceps different software and has factory fitted 3bar MAP. They can be modded eighter way ABY <> ADU.
    • Billman
      • 4129
      AFAIK the ADU has a 3bar map sensor and the aby a 2.5 one!
      Go Holset or Go RS4
      • gavs20v
        • Sep 2004
        • 3057
        if its only the map sensor ill not btoher as ive got one from a vr6,
        cheers
        • spink
          • 4382
          AFAIK the RS2 ecu has an extra resistor in it somewhere.
          • Henka
            • 585
            • Home: Sweden
            cheers
            What? Do you mean that the VR6 has a 3bar MAP sensor??? I MUST be getting this wrong...
            • dan_b
              • Sep 2003
              • 3670
              If you're getting your ABY remapped anyway with all your new custom hardware, I'd not bother with the RS2 ECU as you'll still need that remapped with what you're putting in. Besides, do you know where that ECU has come from? ...
              • porkkis
                • 1994
                Dan, from bosch factory?
                Sorry I had to
