could radiator be blocked ?
  • s4_rider
    • Apr 2004
    • 44
    I have the following phenomena.
    The radiator fan goes on at 100 degrees in stead of 92.
    The temp switch is OK.
    I put it in hot water and the fan goes on at +/- 92 as it should.
    Could the radiator be blocked somehow ?
    S4 Rider
  • quattronutter
    • Jan 2005
    • 690
    innacurate reading from temp gauge?
      I'd concur, reckon the temp sensor in the rad is probably faulty.
      Anybody near you that you could try their sensor in your car?
