Hi all,
Tonight I looked into the turbology paper which pauln made, great Info , thanks for sharing
I did this because I am looking for an alternative for the rs2 turbo. I am looking for a turbo which can make lots of low rpm torque and more then 400 hp. I compared the garrett T04E 50 and the garrett T04E super 50 trim, I found (dont know if it is correct?) the super trim 50 more intersting as a replacement for rs2 turbo. I think it can make 2 bar at 3500 revs and do over 400hp and will not exceed 600nm, so I can hopefully stick to the standard rods. I read that the rods will not bend due to high hp outputs but due to high torque, exceeding 600nm.
Can someone tell me if I am correct? Has someone this turbo already fitted, Dynoplot maybe?
thanks,
Erik
thanks,
Erik
