Piston Cooling Canals
  • Billman
    • 4129
    Hi, i read somewhere that there is been used in racing turbo engings cooling canals with oil!
    The piston has an oil channel inside!
    Each time the piston goes to the lowest position the hot oil comes out and the coller gets in!
    Does someone knows more about this?
    It says: The piston have an 45cml oilsea inside! The piston is cooling through fresh oil that pushes the hot oil outside the oil channel with an 3.3mm oil injector!
    Go Holset or Go RS4
  • Billman
    • 4129
    OK, i did a little research myself and came up with this!
    Go Holset or Go RS4
    • Billman
      • 4129
      This is from Mazda 323 GTX-GTR
      Go Holset or Go RS4
      • Billman
        • 4129
        They say this cooling system is much more effective than oil Spray systems!
        And the questions are:
        1. Can this system be adapted in the audi engines with custom made pistons?
        2. Can Piston manufacturers (JE ect) make pistons with oil channel or must they be casting pistons only?
        Go Holset or Go RS4
        • 4WheelDrifter
          • Oct 2004
          • 5773
          • Country: Devon
          Like these?
          SS
          • 4WheelDrifter
            • Oct 2004
            • 5773
            • Country: Devon
            Not sure about the pistons though.
            SS
            • Mark Halligan
              • 2001
              Originally posted by 4WheelDrifter
              Like these?
              Mmm I recognize that block and bike wheel.........
              Mark - Modded
              • Billman
                • 4129
                Like these?
                I think these are stock Oil sprayers in the audi 2.2 Turbo and diesel engines!
                I mean, can there be oil injectors to use with oil channel pistons in an audi engine?
                Go Holset or Go RS4
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  He he. Thought you might.
                  SS
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    I think the pistons would be heavier as a result. I wonder how much, and what advantage there is with this system. I suspect they would be more expensive to produce too.
                    SS
                    • diesel des
                      • 3896
                      The new 130 150 and 160 1.9 pd tdi ve/audi engines have hollow pistons with the oil jet. Not just a oil just like the old tdi,s and 20VT but a oil "pocket" like you describe. But then the new diesels are under huge thermal and compressive stress compared to even the highest tunned 20VT. Dont think it would be needed on a 20VT if the fueling was right. Very nice kit!
                      • Billman
                        • 4129
                        It will be needed not to run so rich on Full throttle! Less knocking, smaller intercoolers, ect ect
                        Go Holset or Go RS4
                        • Billman
                          • 4129
                          Answer from JE pistons:
                          No problem...A set of 5 custom JE's for Audi with Oil Channels is $825
                          with wrist pins and rings.
                          Add $245 for Ceramic Coated Crowns and Moly coated Skirts and insides.
                          Another Wuestion that comes is: What oil injectors to use?
                          Another thought is: With pistons like these the oil must go very qick hot, so maybe a very big oil cooler is needed, and may for the few who can a Drysump system with 8-10 liters oil!!!
                          Go Holset or Go RS4
                          • Billman
                            • 4129
                            So people what is your opinion on these kind of pistons? Anyone heard of someone using them?
                            Have also find this picture on this site http://emporace.com/ but i cant understand what he says! He has JE pistons they look so:
                            Go Holset or Go RS4
                            • Billman
                              • 4129
                              nobody?
                              Go Holset or Go RS4
