how do i calculate injector flow when fuel pressure rizes?
  • zlobo
    • 967
    does any one have a formel for that?
    ABT C5 Lord Of The Rings
    2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
    2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
    2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
    kostic.nu
  • Audi Parts Guru
    • 1317
    The only reliable way to work out injector flow rates is to test them on an injector flow rig. Increasing the fuel line pressure will only increase injector flow rates up to a certain point and once that point is reached you will not get any more fuel out of the injector no matter what.
    I have watched an actual test whereby a set of injectors were being flow tested on a flow rig and the pressure was manually increased. At first there was a small increase in flow rate but once the pressure got to about 5 bar, there was no increase whatsoever
    • zlobo
      • 967
      i was thinking off razing the pressure from 3bar to 3,8bar with 530cc@3bar injectors.
      So i am wondering how much they will flow at 2,8bar
      kostic.nu
      • AnLe
        • Dec 2003
        • 291
        testing is only way, rule of the thump is that bosch does not really increase as the pressure rises, on the other hand, deka's seem to flow as there where no limit.. mine 550@2.5bar are over 800 at some über 5-6bar pressure
          There is a simple equation for this. You only need to put injectors on a flow bench to ensure you have a closely matched set of injectors. Gimme a few minutes to find the equation.
          Paul
            (F1/F2) = sqrt(P1/P2)
            Where F1 is the mass flow of fuel at rail pressure P1
            and F2 is the mass flow of fuel at rail pressure P2
            Mass flow is measured in lbs/min and pressure in psi for this calculation.
            A good rule of thumb for fuel injectors is that for every desired 10bhp you need 1 lb/min of fuel. So a 400bhp engine needs mass flow of 40lbs/minute of fuel. There's more accurate versions of this mathematics but this is a good enough to select the right injectors, fuel pressure regulator with margin for your needs.
            Paul
            • Audi Parts Guru
              • 1317
              The only problem with this is the fact that this calculation does not allow for injector production tolerances as these can vary quite considerably. I have personally seen production variations in flow of around 10% . A performance road car should have an injector flow rate variation of only about 3% and a race car should be 2%
              Injector flow rates should be calculated at 100% duty cycle
              • AnLe
                • Dec 2003
                • 291
                Wrong
                Paul
                True, on multivalve engine, 2valve egines need more fuel to get same hp. And this is for the 5 cyl engine.
                  Rather than telling me I'm just wrong, perhaps you'd like to provide more information and offer up an alternative formula. I dug that formula out from a website as I couldn't remember the calculation of the top of my head but it looked familiar.
                  Paul
                  • AnLe
                    • Dec 2003
                    • 291
                    Well I have measured (rather watched from behind) several tests with real measuring device made by lucas located near techschool(?).
                    I have posted here several times aan/aby and rs2 and my siemens deca test results, with different pressures. My server is down at the moment so I cant post them know but If you have read my posts you have seen those tests results.
                    tests are also made several volvostyle bosch and msd 700-1000cc models and also na engine injectors.
                    • Tommy200rs
                      • 285
                      some flow calculations also here:
                      *** in measurements it counts a lot weather measured with fuel or Bosch tester fluid !
                      *** from THEORETICAL physics calculations you see that the sqrt function makes the "nasty downside effect " compared to normal assumption that the increase of pressure might have some bigger meaning (see Paul´s et others calculation examples)
                      A real life example from 2 weks ago with rs2 green injectors showed the need to reduce the fuel map values when basic pressure was increased from 3bar to 3.8bar. So calculating and testing gives the best results.
                      • zlobo
                        • 967
                        thanks for all youre answers
                        kostic.nu
