rs 2 stopped today
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    rs 2 stopped today
    The car was Driveing well yesterday , today started up not problem drove around the corner stopped
    to get something from the house , came out started the car up started running very rough drove 300 metres car keeped stalling ,then i parked it ( pushing ) and it now wont start .Seems like petrol , took the regulator of and didnt have any pressure in rail with key on
    Where is the relay , mines all in german???
    The pump is in the tank ???? under inspection plate in the back of the avant ??? is this correct
    if i need a new pumb which one ????
    Anything alse it could be , any help would be good
    Thanks Jade
    RS 2 580HP
    If you are changing the pump its probably worth upgrading to the Bosch Motorsport one. See group buy.
    I need to sort out numbers and pricing this week
    • Sir Buff
      • May 2004
      • 127
      • Current: Switzerland
      There is only fuel pressure if the motor runs (with starter).
      http://www.audi90.ch
      • s2-1.5bar
        • Sep 2004
        • 193
        • Home: Lithuania Current: United Kingdom
        Check the terminals on idle speed valve. If there there is no proper connection or conection became loose you get vey similar simptoms. As well take the valve off and clean.
        Regards
        Andy
        • jade
          • Jan 2005
          • 1811
          Found problem , i think not fuel pump
          Had the engine cleaned friday run fine it was cold dryed of after ect and after would run fine for a day
          open up the coil packs full of condension very damp even after a few runs
          Dryed & cleaned the coils with contect cleaner & wd 40 car started right away but now its not firing all cylinders all the time they come in and out , runing rough ,What damage could of been done or may be a proper stirp down clean and reassemble might work ???? or is it new coil packs Thanks jade
          RS 2 580HP
